I tried and failed, I think there are curved areas so small that you can't thicken, other solution could be to add a lot of material and make boolean.hi guys I've been freaking out for a couple of days with a thickness!in the annex you see a terminal part that I designed with a superfice.I can't make it solid continues to give me error.someone can help me? ?
Thank you very much
Hello, mik, I'm a bit of a beam with the surfaces, but I feel open on the contact areas. . .Bye-bye.
Can anyone help me? ?
Thank you very much
try to see if it can fit you!hi guys I've been freaking out for a couple of days with a thickness!in the annex you see a terminal part that I designed with a superfice.I can't make it solid continues to give me error.someone can help me? ?
Thank you very much
