create vector logo from image
  • Thread starter Thread starter nioken181
nioken181
Good evening to all,
I hope to write in the correct section; I would need your suggestion to understand which technique to use to create a dxf file starting from a logo that I find on the internet in the form of an image.
the logo in question can be displayed on google images by writing "bicycle bell".
I would need to have a dxf to fit that file into a water cutting machine.
the only technique that comes to mind is to "recalcate" the logo opened in autocad as an object.
Are there better or faster methods?
I press that as software I have available autocad 2016 and do not make it professional but occasional use and for hobby purposes.
I wait for your advice and thank you in advance.
autocad is not a carrier. You can just go after that.
You should address other types of software, see for example illustrator, the first one that comes to mind.
