Staedtlerp
Hello everyone,
I have a problem, I think small and solveable:wink:. Sometimes I happen to have to quote outlines where I need to find an intersection between two lines for example. so far everything ok, active the detection option of the intersection point and the game is done, appears the extension of the lines concerned (tracked) and their intersection identified by a clear green point. Now, apart from the color of that point I have to change, as soon as I activate a different view than the one in which I found the intersection, I disappear the extension of the two lines (the lines drawn to understand us). reappear as soon as the view reacts. I put some photos for clarity. in the first two visible dotted lines with active view, in the second the lines disappear with deactivated view.
the problem is that if I go to print do not appear such lines drawn and this makes the drawing a little unreadable since the references of quotas are missing.
another thing: I noticed that the lines outlined in intersection are considered by catia as elements created, in fact if I activate the view and press on the button "filtra created elements" such lines are highlighted.
exists a way to avoid all this and to ensure that such lines/intersections are always visible?grazi thousand:biggrin:
the problem is that if I go to print do not appear such lines drawn and this makes the drawing a little unreadable since the references of quotas are missing.another thing: I noticed that the lines outlined in intersection are considered by catia as elements created, in fact if I activate the view and press on the button "filtra created elements" such lines are highlighted.
