jim78b Guest Mar 3, 2015 #1 hello to all I found a lisp that from a polyline creates me around a rectangle with but the beveled edges, I want it with the corner edges.... I put the file lisp I own. Attachments buf.lsp buf.lsp 12.5 KB · Views: 34
Dr.Lube Guest Mar 4, 2015 #2 the lisp is protected with "protect.exe" (it would have been wiser to compile it. . ) I can tell you there is "unprotect.exe" .. the only thing to change will be a variable for the fitting to set to 0
jim78b Guest Mar 5, 2015 #3 Dr.Lube said: the lisp is protected with "protect.exe" (it would have been wiser to compile it. . ) I can tell you there is "unprotect.exe" .. the only thing to change will be a variable for the fitting to set to 0 Click to expand... And I find him aprotect? If you can't do what I said?
