warrenb
hi to all I have "problems", if so you can say, with autocad 2011..
-every time I open the program, or better a dwg file already saved the program creates autonomously a file "type source application autolisp (.lsp)" called "acaddoc"... the file varies in size, but generally are few kb... How is this possible? what is caused? not that it is a big problem, but it is a nuisance every time delete these files.. .
-why if the program is closed and I open a saved file, autoca 2011 also opens a new file and is not limited to what I asked him?
- at the start of any file or new file the grid is... I can disable it, of course, but if I close the program and restart it, will you continue to be there? Why? Does it happen to you, too? Is it possible that he has activated some ticks that imposes this fact?
Thank you, I expect your answers!:smile:
