creating popup or text message
  • Thread starter Thread starter mastmotion
mastmotion
Hello everyone,
that you know, there is a way to get a window out with a message inside reading the values from the expressions?
I'll explain better.
I have a cube to which I said in the expressions that the lengths are l=100
always in the expressions there is a control string that you if l=100 ok but if l=101 is not ok, and it is here that I would like to make a popup or text message appear.
something like this is the check inside the expressions themselves, but it's not what I need, as I must always check the part navigator to see if there are errors, while with a beautiful window that comes out in the foreground, you know that you have to stop and correct everything.
thanks in advance;)
