creation dwg using catia v5
  • Thread starter Thread starter Maury Ghibba
Maury Ghibba
Good morning.
I am a torino designer who works in both fabrics and solids.
I would have the need to transform catdrawing files (created with catiav5) into dwg files, but I noticed that using the command "Save with name>dwg" both quotas and texts, once opened the dwg file on driftsight or autocad, turn into polyline and are not recognized as texts.
Moreover the quotas are "disappeared", as well as the texts themselves.
Would you kindly give me some advice on this?
first of all thanks to the answer.
in tools/options/compatibility unfortunately I can't find any voice saying "export mode"
I was also looking for something like this but after doing a test I noticed that if the design is scaled the quota does not follow it.
example: 100 mm line in scale 1:4 is quoted 100 but when the dwg port finds me a 25 mm line quoted 100.
you can bypass the thing by changing the altitude scale in autocad bringing it from 4 to 1
Excuse me, one more thing:
How come when I go to create the dwg the odds appear to me as in the attached image?
the symbol of the "pollici" seems a bit distant from the numerical quota itself, as well as the square brackets that go to indicate the measure in mm.
is there no way to approach the symbol of thumbs and square brackets to the numerical quota?Cattura.webp
Hey, I got to figure something out. .
you exported a dwg or dxf from catia and then you're reading it with autocad or her like?
If so.. you must try to change the style of listing in the software to which you read the dwg/dxf file from catia.
catia has nothing to do with it, I think it's a setting of the autocad software quota style
you could test the 9 .. opening with catia the same dwg/dxf created with catia
exact, I have to turn catdrawing files into dwg files to open with autocad or simil (draftsight).
I tried to do what you suggested to me, that is to open the same dwg file (created by catia) on catia itself, but the result is quite strange...I do not appear the quotas in inches, but only those in mm.
in any case I thank you for the kindness
