creation .dxf file not updated
  • Thread starter Thread starter Quoque69
Quoque69
hello to all
as indicated in the title I happened to receive laser cutting components not drawing because the dxf file was not updated.
from what I could reconstruct the file created as sheet metal, (as I think is normle ) during the design phase undergoes several modifications but the flat model did not update moral the piece was shorter than 20mm.
Has anyone happened?
we use iv2019
thickness is correct
in the specific file there were no folds the flat model was created to speed up the creation of the dxf file
thanks to all in advance
the dxf file is not related to the inventor model.
It also happens that the flat model ( 3d ), following a little more "complicated" changes, does not update.
in which case it is necessary to cancel and regenerate it.
Sometimes it happens if you change the sheet with the command "direct change", personally I always try to avoid it, considering that I consider it a command of modeling and not of sheet metal
erase the flat model and remake it.... it is very right, the only drawback is that you lose the possible view in table 2d with its quotas.
I always use this system, which I sincerely do not know if it is influential or not, but I always knew that it helps to generate sheet development (I use it in a "automatic way since iv6 of 2002), that is before creating the flat model 3d, I touch a face (usually the main) with the mouse arrow (theoretically I hold the piece steady).... I don't know, maybe it's a cabbage, but it works, often realizes
Good job
Shut up, they copy you, on 2021 they will put a command that will do it.
will be called "gong-boing "
but, perhaps in part, have they already done it?1560801777788.webpbefore creating the flat model, you can define the side to or select a face than to execute the explanation. the side to specifies the direction at the top of the part. a selected face explains the part using the selected face as a base face
