stefer
good morning to all, I have to create a conical hole to create an oblique injection channel (45°) to connect the upper channel where the injector nozzle to fill the rubber cylinder (i.e. in the 2 hollow rooms/figures). the channel must start from 3 mm and finish diameter 1.5 mm. I should look for the fastest method to make it... But I have some difficulty. I used the loft command creating an initial circle (3 mm) and final (1.5 mm), but not being aligned to 45°, the output came in the form of ellipses.
advice? I train the step.
Thank you, stefano.
Thank you, stefano.
