creation of a pipe
  • Thread starter Thread starter ingegnere000
ingegnere000
Good evening to all, I tried to search the forum but I found nothing to do with my case.
I would like to create a simple pipe with 90 degrees curves that extends in the three directions so a simple sleep is not enough.
I don't know him well.
in inventor it was simply to create passing plans for the center of the tube and then sweep away.
I read that there is a pipe command but in mine I can't find it.
use creo 3.o
is it not possible to follow the same reasoning?
from the first sweep create a parallel and passing plan for the center and then continue like this.
I create the plan at the end saddle sweep but it doesn't make me rotate it.
I feel like I can't make plans for myself as I did with inventor.
Unfortunately I am obliged to use creo.
thanks to anyone who will respond.
umberto
if you want to use the sweep function you must sketch or select the trajectory of the tube and then draw the section, which will be orthogonal to the trajectory.
sent by my sm-g950f using tapatalk
