creation of rules on parameters
  • Thread starter Thread starter roby295
roby295
I have an example of my caty problem.
Suppose I have two parameters... a=5mm and b=20mm
I would like the parameter to always be 5 mm until b<20mm. so if b>=20mm then (for example) a=5mm+2mm
Is this kind of operation possible? If you like?
Hello, you are possible. I can't access the program right now, so I'm going to memory. Right-click on the paramentro (or quota) modifies the formula (or something like that). alessandro
hello thank you for your help first.
I to the point, from you described, are able to arrive and also set simple formulas of type a=b*2. the problem is instead to set a rule type like the one described above.
Could you be more detailed then?
please is very important
as written above at this time I cannot access the program. Did you practice that formula you posted? (more I don't know what to tell you)
Would a simple excel table try to solve your problem?
