andr34
I am new with microstation and I would need an address to know what and where to look.
I should create a procedure to print a topographic paper at 25 thousand,
I explain: I already have a file micrstation v8 with simple centerlines of the streets (different with different levels in overlaps, galleries, etc.)
However in print the road must have a print style with black edges of a certain thickness and filling for example yellow,
the centerline of the overweight for the same type of road is on another level and must be printed on the road below, finally the section in the gallery will have to be printed with the bordered and without ticking and under the streets.
another type of road will have red and white filling, like igm cards and via this step.
My question for now is very simple since I still don't know what to look for, could you indicate where to find something to read to do a procedure to print these centerline curves with the desired look?
and possibly if possible that allow me to print also on pdf
Andrea
Andrea
