creation plan of work on a uniqueness
Alexsmie
Hello everyone, I am self-aware the use of inventor 2010 ... is not going wrong then, but I am always stuck when I have to build a tree with a stick on the taper... I can't create a work plan on the conicity .. help me? ?
I usually do them with a tangent plane passing by one point and drawing the slot for the stick and extruding it (make the tree, create a sketch where to place a point and use it to create the plane together with the sloped surface of the cone)
I don't remember if it's an existing command on 2010 if it wasn't, then make a plan and bind it with the angle you need
It's late... I wrote an idiocy on binding the tilted plane....... .
do a sketch on one of the plans of origin, draw a rectangle with the inclination that interests you, remove the material for extrusion, and smooth the edges
If you have generated conicity through the revolution of a sketch, do so:
make the sketch visible, -> piano- > click on the conical line -> click on the conical surface.
