creation single part
  • Thread starter Thread starter StudentCaD
StudentCaD
Good evening, I started a gooseneck for a trunk and should do the part below that but it is making me tribulate more than I should. On the assumption, as I have already said in other discussions, that I am not an expert I would like to know how to do it. I also attach a photo. basically to make the edge I used a multiple extraction by selecting the interested faces and after that I created a 3 mm offset of edge and 7mm of depth. the difficulty comes now, where I have to do all the structure below. What can I do? creating a sketch seemed to me the best idea but it turned out quite useless as it is too long and difficult both for the measures to be copied (because it is an existing piece that I am using as reference) and for the structure. the photo I leave is of the part below, exactly what I have to do. thanks in advance for patience!
I'm sorry, I didn't understand anything about your long explanation.
If the object of the photo is what you have to do, it doesn't seem complicated at all.
Unless... if you add another view of the object we find that the universe is behind it?
