creo 2.0 - impossible to make threaded holes
  • Thread starter Thread starter Dancan
Dancan
ho un modello fatto con creo 2.0 su cui risulta impossibile fare dei fori filettati .
il messaggio che mi dà quando vado a posizionare il foro è il seguente :
the clearance between the thread surface and the drilled hole is at the same order as the part accuracy.
hole geometry could not be created.
select up to 2 references, such as plane, surface, edge or axis to define hole offset.
qualcuno mi sà indicare come risolvere il problema ..se no devo fare il foro+cosmetica come feature separate , il chè mi sembra abbastanza assurdo.
never happened, try to change the overall tolerances of the model, I don't want you to have strange settings. . .
Did you start with a start part modeling? What settings do you have in size and tolerances? go into model property and look what it says.
If you can attach the part I look at, I have the 1.0 but...
I practically can't and I don't know how to set acuracy in part environment.
in the wildfire versions if you want to set or change the acuracy other than the default one you perform : edit-setup-accuracy (relative \ absolute) .
in creo 2.0 the edit command has disappeared .... , how do you set the accuracy?? ?
the edit command was the one that grouped all the editing and setting options ... in I create many of these spread them considerably worsening.
file>prepara>set model ... and from May 6 you can't find the command?
then they say that there is the crisis... :-)
First of all, thank you for the answer, secondly, I do not permet to certain observations 1) I do not work with creo 2 I have happened to put hand to some models 2) if everyone did from 10 to 12 h working hours by turning off the monitor of the pc beyond midnight almost all nights .. maybe things would be a little different.
greetings.
greetings.
the problem is that you don't want to look for the command and come here to ask questions for which a little good will would be enough.
I didn't find it at first, and after 3 minutes, the command came out.
If you don't like the "style" of the subscriber you can always turn to the customer care of ptc, you pay it well and they will give you all the answers you want.
n.b.: as you see, I answered that it was not yet 6:00 in the morning... so your answer bounces me.
