creo 3 use default masks in the markings
  • Thread starter Thread starter faguide
faguide
Hello everyone
someone can tell me how I can set already by default " use default mask" (that caselline to be ticked down to left) so as to automatically set the start drawing (see attached image)
Thank you
should already be checked by default from the system, check not to have a setting that says the opposite in the config.
to help you, view the config by category.
thanks by default is not set, you would indicate the item to check in the config.
I tried to find, unfortunately I didn't find anything about it.
Do one thing, momentarily, move the config and check if you reappear the tick, by you know if it is a setting in one of the config present.
ok congratulations, adesso provo
