creo 8.0 setting parameters export step
  • Thread starter Thread starter emmegi64
emmegi64
greetings, I have a problem with creo 8, in previous versions, when I wanted to export only a few parts of a set in step, I hid the parts that I did not want to be exported and the resulting step contained only those visible at the time of the command " saves copy step" now does not do it anymore and every time I have to enter the export step configuration file and deflag the item "hidden entity".
how do I set this up so that it is always active in any director?
should you put some voices in the config.pro?
I don't use it anymore. I don't even have a chance to see.
from what I remember, if you can deflag the item "hidden entity" then you simply need to save the step export configuration file and then recall this file in the config.pro.
this is the line of the config.pro as I had it
export_profiles_step c:\ptc\supports\sets\def_profile. dep_
p.
when I needed to export only a few files for any reason, I created a simplified representation with the only files to export
hello, in the meantime I had arrived just to what you wrote me, I still have the problem that I don't want to point on what I wrote in the config.pro and I have to understand why, since at this point the right road is just that and the string is exact
Thank you very much for the support.
Try to put the string here, maybe there's some mistake that doesn't jump to the eye
I take it for granted that you have closed and reopened I create to make him load the config.pro
it is obvious to restart the computer figurative
Here is the string
export_profiles_step c:\labor\trail\trail creo_8
that's the directory where that file is.. hmmm then in the string I have to add the file name! Okay, thank you.
ok works thank you so much, I was convinced that it was enough to give him the destination where the file was, I had not observed your string
Thank you very much
is not the section to put requests of creo, here we talk about mechanical design in general.
ask moderators to move it so we avoid confusion and facilitate research.
