the simplest solution is a batch command, but it depends on how the files are stored.
If you mean a unique command, I'm going to do everything automatically, without a pdm running it, no, it's not.
Meanwhile thank you for the answer.
in the company I am without pdm and I imagined already it would have been impossible to do everything from creo.
a batch would be fine, the drw is contained in a generically called 3d folder containing all parts and assemblies. above 3d folder I have pdf folder and dwg folder where I should go to save files.
