ctrl+q automatic
  • Thread starter Thread starter czar
czar
I've been a little rich lately.
I have views that do not update unless you manually do ctrl+q once open.
I press that:
"Consent automatic updating when opening drawings" is selected
"Reconstruction verification" is selected
Is there a function that performs an automatic ctrl+q at the opening of the drawing? I'm looking for half an hour now, but I'm starting to believe I wouldn't even find a cow in a bathtub.
I press that:
any views or views of the table?
Sections?
automatic ctrl+q does not exist unless a macro, which you could record.
try to make attempts in case they were just a few.
do a save by the name of the table and start to erase a view at a time and at every cancellation of sight a new save by name.
When you do not find the offended view and try to give you a reason for your behavior.
the view is one and only in that you see the holes in the section. to see if even the other views have the problem I have to put some quota because the shift is not visible to the eye, it is tenths. another part, quite similar, has no problem and I'm missing the test to see the differences between the two.....
I'll try to do as you know... thank you1000
