_Vale_
Good evening, everyone. I am new to the forum and I would have a question maybe banal for many of you. I will try to be brief: I have a plan of construction of a hull (only transversal) in pdf. I cut it and saved it as jpeg and opened it as a background bitmap. I then began to recalculate the curves with the "curva per punti" command. I don't know what I did, but with the same command, I don't get the results before. If I click on the background curve, the point is not placed where I indicated but in a different position. the curve obtained therefore no longer follows the "original" that I have to recalculate but does of the ondines, more or less accentuated depending on the degree given in the settings of the curve. the same thing happens using the "interpolated curve" command though in the instructions, the short film shown, shows a different result. What I'd like to get!
I certainly changed some setting that I didn't have to touch!
I hope to receive some indication from you who know how to use it! !
Thank you
Thank you
