custom properties in separate
  • Thread starter Thread starter Riccardo81
Riccardo81
Is there a way to insert columns with the custom properties of the part in the distinct of the overalls? use the 2010 version
impossible not to work. If you save the table pattern, then next time select that table. by default if you do not choose from the list of tables makes you use the standard.
to know the procedures that are made you could give a sensible answer.
but if you write "it doesn't work" the best answer is "bho" or "held"
