isoladimann
Hi, guys. . a simple simple domandina, (with the search button I did not find what I needed, and if it was already dealt with the subject I apologize)
when you generate the "design sheet" 2d from a 3d model (which then is only a 3d model plant view), in making cross sections, I only want to "cut" completely (from one side to another) the particular ceh I want to dissect. . .
but if one needs to run the sections.. What do you mean, corner?
I'll explain. .
I draw a cube with 3 holes passing on a face, in different positions. .
I would like to be able to pass my section including all 3 holes centers, so as to have a section not straight but "scaled". I don't know if I explain. .
and instead I can only dissect with a "rect". . .
greetings and good lunch dear. . .
I'll explain. .
