customization in visual basic
  • Thread starter Thread starter The-Edge
The-Edge
Good morning to all,
only an information: exists of online documentation that helps to perform visual basic customizations for microstations?
e come si fa' :confused: ? a scaricarlo intendo .........
questo è il msg. ch mi viene fuori:
forbidden
you don't have permission to access /~ejm9k/arch548/docs/microstation_basic.pdf on this server.
additionally, a 404 not found error was encountered while trying to use an errordocument to handle the request.
apache/2.2.21 (unix) mod_ssl/2.2.21 openssl/0.9.8r dav/2 php/5.3.8 mod_pubcookie/3.3.4a server at www.arch.virginia.edu port 80
but is it a public pdf?
hi, I have been using microstations for years, if you need some clarification on personalizations, I can give you some knowledge of me. so create the "sbm" and use the vba for customizations of levels, line styles etc... I use v8i version
What are the "sbms"?
hi, in c:\program files (x86)\bentley\microstation find the .chm files of the vba
search *.chm in this directory and you will see that you find them (v8i but also other versions. ..
sbms are customizable sidebars chye enclosed keyboard commands for certain functions.
in one row you can say : level 1, line thickness 3, line style 4, etc.
If you want, look at this little sbm I created. save it in any folder and then with the drag&drop the "transcini" inside microstation.
ps the file that was attached, you have to rename it with "sbm" extension. then golf.sbm
