use the sketch you made with extrusion cuthi to all I have to cut the part that is highlighted in photo, I tried with loft and sweep but I can't, you can tell me a way
I tried with extruded cut but says it is impossible to reconstruct it because of geometric constructionsuse the sketch you made with extrusion cut
Well, of course with that image... we can only imagine, in fact,hi to all I have to cut the part that is highlighted in photo, I tried with loft and sweep but I can't, you can tell me a way
Maybe the line doesn't completely cross the bodies to cut?I tried with extruded cut but says it is impossible to reconstruct it because of geometric constructions
I uploaded an image, in this is the profile of the part that I have to cut, with a corner of curvature that is that in the drawing in figure 1, you should understand how to doWell, of course with that image... we can only imagine, in fact,
Your problem!
corner of curvatureI uploaded an image, in this is the profile of the part I need to cut, with a corner of curvature
I didn't understand a bat and frankly I just don't want to do cross-checks with the other image you posted to try to find inspiration and provide you with the umpteenth solution (fielded by air) for what I think you're doing.. .that is the one in figure 1, you should understand how to do
I don't think it's hard to cut the piece, too.I attach the original file, I have to cut the piece obliquely as they mark the lines in the first figure I sent, I no longer know how to explain it what to do, It doesn't seem difficult to understand from the photo, I just have to practice an oblique cut as the first figure shows
mikele thank you now I understand! ! !You try it, too, in 69" I fixed... :biggrin:
Look how beautiful it would have been if you had posted an image
Of the kind:
but read the help.mikele thank you now I understand! ! !
Okay, thank you.but read the help.
