enriazzo99
Good morning to all I have a problem about cutting a flange of the edge of a sheet. in the "capture1" screen I made a cut with the "extruded cut" function but I create a small fold that in the bending phase would be unrealizable. I was trying to figure out if there is a possibility, after having already made the flange of making a cut as I did in the "capture2" screen. this because in the capture two I had to eliminate the flange and cuts and realize again 2 different flanges and I do not think it is a very fast method.
thanks in advance
thanks in advance
