da 3d max a solid edge
  • Thread starter Thread starter frencisis
frencisis
Hello everyone who knows how to explain xkè importing a 3d design from autocad in 3d max 2009, then imported into dwg, and then exported to iges; solid edge does not open it to me?
thanks in advance
because max iges does not export them (unless you do not convert them all after importing into nurbs, but I do not know whether it is true, certainly from polygonal to iges does not export anything...).
Try to see the iges you exported as much as it weighs... will be about 1kb, which with an iges also simple is impossible.
so for export dv convert dwg to nurbs and how do I?
Is there another method to export them to solid edge? I also tried the stl format but I can't add feature what is possible with iges
I don't remember, but can't you export from autocad directly to stp or sat or x_t?
no xkè in sat does not understand me the surfaces...in fact I served max x that reason
boh, I don't know what to tell you, for sure the pass from max is not the right way.
if you can go directly into step or iges or x_t by autocad if you can (I don't remember).
but if you don't see native dwgs too?
Do you know how to export the surfaces by using the satellite command? He only exports me solids!
ok thanks I posted the request also in the forum solid edge see if they know it
