zueno
I occasionally use cad and gis systems and I will try to be as clear as possible. . .
I have a dwg file with level curves created as a block... I explode (using autocad) because I have to bring back the individual level curves in arcinfo and then turn them into shp, the casino is that in archinfo each curve is "microdivisa" made of small pieces. . .
Is there an arcinfo command that reconnects the pieces of every single level curve without recreating the block? ? ?
help!!! Thank you.
help!!! Thank you.
