da schizzo a drawing
  • Thread starter Thread starter nerork
nerork
Hello, guys.
as from object I would like to know if it is possible to draw in the sketch of the part and then import that sketch into the drawing.
I would like to make a 2d drawing with catia, and since on drawing it is not possible (use of limited constraints) I had thought to use the power of the sketch.
Can't believe it? :) Would you like to use caia in 2d??? You don't want to. even if you need to draw a simple cube... first create the part in 3d and then make the table automatically.
Hello, guys.
It is not at all true that the 2d is limited, you can do the same things as the 3d sketch, you just have to activate the creation of the alleys (see toolbar).
this can then be copied into sketchy environment.
Thank you, I will give you a try. I am pleased that there is someone who answers intelligently without hearing or making unconstructive statements, every reference is random. Thanks again
you can do it, just enable the representation of wireframe lines underl and 2d view properties.
the 3d will pilot your 2d
Hello, guys, I used catia for a sketch modeling it in the "sketch".
the model made in the catparte file does not contain 3d solids.
Now I wanted to bring everything back to the "drawing" environment to make a complete table of quotas and cartiglio.
is it possible to do this? I would like to avoid redesigning everything in "drawing" and use the "sketch" environment for any changes.
Thank you for your help.
Hello, guys.
Hello.
I also used catia for a sketch modeling it in the "sketch".
How did you solve your problem? Thank you for your help.
Okay, done, thank you.
I enabled the representation of wireframe lines under 2d view properties
strumnti -> options -> drafting -> view ->proiett wireframe 3d
ps: I was urgent to solve the problem and I did not read carefully. ;
the same option you can enable it directly in a view without having to impact all your drawing
go with the maus on the view, right click on the red rectangle of the view, choose properties and you appear the window with the options
