datum deformed components
  • Thread starter Thread starter Alx84
Alx84
Good morning.
I have created a deformable component, the mont together and deform it, at this point you create a datum near the deformed component that you cannot select and hide.
Did someone find a trick to hide such datums?
sometimes it indicates how normal a behavior that really is not, I have never seen datum appear in a deformable component, maybe if you place the file, if possible, someone can give you a suggestion.
c.
incorrect corrige, it is not a datum but a "coordinate system".
I attach the image, to the right the plate mounted together and to the left the same but deformed.
you can see (in blue) the created coordinate system.
look well at the reference set of the deformed component, probably set on entire part.
the reference set is set to model in fact the datum (the one with the plans and the axes) is not visible.
This coordinate system (blue) seems to be a clone of the one present within the part and appears after deformed.Datum 2.webpin the image from right to left:
mounted component (entire part)
mounted component (model)
deformed component (enter part)
deformed component (model)
try to do this: put the main datum in a tot layer and then disable this layer together. Something like that happens to me with the user defined features and so I can hide the coordinate system.
Okay, I'll try this way.
I would like to find a method, if it exists, to automatically hide these coordinate systems or make sure that they are not created.
Thanks for the advice.
