[dbworks] popular database from existing files
cacciatorino
they sent me a zip file containing several thousand components of solidworks file library. These files already contain the compiled anagram properties.
Now I should insert this data into dbworks, but using the tool:
setup tools --> registration documents in the database
and mapping (at least I believe) correctly the fields:
database field <--> custom property
it happens that the import does not go to good end, i.e. the only data created correctly is the id (earth equal to the file name), all other info is left out.
Note that the database field in which the values of the "custom property" are already present in dbworks.
swx 2010 sp4, dbworks r11 sp4.0
Have you tried dragging the file inside dbworks and see if cust prop mapping works? in any case it also controls dbworks options (data input -> import custom properties as field values using mapping schema/custprop.txt file).
Say hi!
Say hi!
I've been working out for a long time.
Thank you!
