My_Key
Hello.
I wanted to know if there is an option or command that allows to disable the 'undo' function regarding the views and the 'zoommate'. I mean, if I hit a close-up element, and then I'll be backed up to look at the result, I'd like to be able to undo the editing command without zoom and visual change. It will be that I'm used to archicad, which you want to do,
but I still find it a bit annoying, even when I work in autocad.
Thank you
Thank you
