debuts the durc online
  • Thread starter Thread starter gfrank
gfrank
Decree-Law 20/03/2014 n. 34: urgent provisions to promote the relaunch of employment and for the simplification of the fulfilments to the burden of the enterprises
the durc online. the regularity of contributions may be ascertained with a single question in the databases of inps, inail and building cases, entering the tax code of the subject to be checked.
with the communiqué of 5 June (protocol 45482), addressed to the territorial offices, the inps announces that the whole iter of definition of the regularity of contributions must be completed within 30 days from the application. the announcement follows the first instructions issued by the Ministry of Labour in recent days on the online passage of the durc’s release procedure, mandatory since 1 July 2015.
it also considered it appropriate to highlight in summary the process itself, therefore from 1 July:
– Enabled subjects will activate the verification by indicating in the dedicated procedure the tax code of the subject to be checked;
– if the archives of the inps, of theinail and of the building cases do not detect any defaults, the procedure will automatically generate a document attesting the regularity;
– if irregularities are detected from the archives of the inps, the territorially competent office will have to check immediately and in any case, in compliance with what is required by the Ministry of Labour, no later than 72 hours from the application of verification, if the indicated defaults are real or the effect of unfair archive evidence.
in this second case, the headquarters, “forcing” procedures, according to the procedures already in use in the procedure durcinps, will attest the regularity of the verified subject;
– if the default is confirmed, the territorially competent office in the same period of 72 hours will activate the procedure of communication of irregularity, this will award to the incomplete subject at least 15 days for regularization, in a manner similar to what is already foreseen in the procedure durcinps;
– the eventual regularization will determine the release of the certificate of regularity, while the failure of regularization will result in the communication of the negative outcome of the verification;
– the whole definition iter must necessarily be completed within 30 days of the verification instance.
to make the procedure clearer, the inps with circular 126/2015 and the ininail with circular 61/2015, have made the point of the situation on the existing norms
