Atreiou
trivial problem but I can't solve it, it happened both its 2017 and 2020
for embellishment of renders I have to apply decals on solids, mainly vertical cylinders
example, they place me on the front view, I see the cylinder placed vertically, I stick the decal on the surface.
the only settings that work in "map" are "tag" and "projection"
with projection is good enough, I can place the decal centrally, with the only problem that the same is replicated on the back of the cylinder, of course reversed, as if it were "passing" through the cylinder.
with the label setting, in my opinion the correct one. the default decal is applied on the back of the cylinder, and if I slide it on the front with the horizontal slider of the position adjustment, the same arrived at the center frontally begins to disappear making it impossible to adjust the position.
Did someone find the same problem and have a solution?
