decimal digits imported parts
  • Thread starter Thread starter Solid User
Solid User
Good evening to all,
I write to ask you how to set only two decimal digits after comma in the mass property of imported files.
if I create the file part, the mass has only two digits after the comma (set as unit of measure the kg); if the file has been downloaded (as from attached figure) it reads five.Capture.webpDoes anyone have any suggestions?
Thank you, hello!
because when importing the neutral file uses the default model set in default model options.
If you want to use another model, you need to change the address or, in case you need to use different models, check out ask the user to select the document template
Thank you!
can you change the model of a downloaded file and already saved in .sldprt? so you have all the same settings?
No.
you can try to load the settings of another model. look at the options>property of the design standard document
