TECNOMODEL Guest Jun 7, 2016 #1 as from title I would need to have the odds of a table holes with 3 decimals after the comma. Can't find where to set this up, any help?
stefanobruno Guest Jun 7, 2016 #2 change style " table holes " --> formatting tab --> dx button on " quota x " --> column format --> accuracy 3.123 --> ok idem on " quota y "
TECNOMODEL Guest Jun 8, 2016 #3 Thank you. I noticed that if a table has already been created does not update by changing the style. Is there a way to update tables of a table to the new style or should one be changed for one?
stefanobruno Guest Jun 8, 2016 #4 select the table and go to the "size " bar at the top, click on the box you see highlighted in the enclosed jpg Attachments set tabella.webp 30.1 KB · Views: 2
