MARCOC
good evening with solid and possible vary the defaul parameter for bevels, make sure that instead of 10mm promises me as the first different value chosen by the user?
Thank you
Thank you
I think it's possible through programming, I thought you were talking about standard sw controls.absolutely yes j, you can set the increment but apparently not the start
maybe with some programming tricks and possible (but only you can put hands on it and you have the experience to tell if it is possible or not)
hello j good day
