default location
  • Thread starter Thread starter MaiMollare
MaiMollare
Good morning
I would like to ask you if any of you have ever worked with axioms from abroad, specifically from the wool. I from Italy have verified that their default location is different from ours and this is creating considerable problems with the assemblies. I would like to ask you if there is a way to make them identical.
p.s. we both use wildfire 4
Thank you very much
I often work with the wool, but it never happened to me. what is different? the default should be default.
hello ozzy thanks for the help
theoretically assembling 2 subaximes in default location, one created by me and one created by them, these 2 subaxiemes should match on a surface they have in common. but when they insert my set, it appears rotated and in another position in space.
I wanted to add that the surface that has subassiemi in common belongs to a same skeleton present in both subassiemi, placed in deafult position, the problem is that this position is not identical for all 2 subassiemi. I hope to be clear, I find it a little difficult to explain it in a few lines.
I can tell you this.
the default bond is nothing but the alignment of the component coordinate system (part) with the default coordinate system of the axieme.
So I assume that your problem arises from the dact that their default sisco of the axieme is different from yours for this they see it rotated, this you can immediately understand by opening a them also empty and your start part will have two different orientations of the sisco.
to solve just align the two.
Let me know.
thanks ozzy/andrea
I have verified, and the sisco have different orientation, unfortunately while being a same company we are in 3 different countries and the Chinese did not use the templates of the other 2. Now we see who will have to change the assemblies, but at least we know what the problem is.
thanks again, very useful as always.
of nothing.. use your own justification that orientation is better than others... :mixed:
do not worry there is worse because it can happen even in the same place but in different departments because someone does not respect the rules and has different leaders.. .
ps: every reference to people made or places is purely random...:cool:
