default rays based on thickness
MARCOC
hello to all...in solid and possible in sheet metal having the setting of the internal rays set according to the chosen thickness...I choose the thickness and the radius he sets it according to a table set? ? ?
(for those who know inventor as the bending rules)
You need to create a gauge table.
once created, add it to system options.
when you create a sheet, to the "lamiera" function, change and choose gaugeCattura.webp
simone... you spy on the values under the rays what are they??? ? because if I in the model change from selection radius 1 or 2 or 3 development does not change
1637841957712.pngof course on the test table or totally different values below 1 or placed 0 under 2 0.5 and under 3 1
View attachment 63870of course on the test table or totally different values below 1 or placed 0 under 2 0.5 and under 3 1
After changing the table, did you upload it to the model?
Once loaded, a drop-down menu appears where only the thicknesses you have tabled appear.
but I don't match the developments, if the coloured values below the radius are the k, the developments don't come back.
another thing between the angle values that from tables jump 15 degrees in 15 degrees, example 90-75 always admitted that the value under the radius "and the k" for an angle of 85 degrees that value the inputs? ? ?
I wonder why there is no more user friendly command. I make a tremendous effort to understand what and how to change on these excel sheets... .
I don't know if you use the table.. and if it works well, I place an example file where if I change the radius to a plague always choosing it from the table, in the model it does not give me error, but when I repeat flat it creates u error on the fold of the model (not the flat repetition)
Have you ever happened? You know how to solve this?
Cattura.JPGGood morning,
I'm probably telling you that some value in the gauge table is wrong.
when you see a function in yellow, right click and do "what happens" (or something like that, I work with the English version for macro creation)
I've put the warning window on you.
Yes, yes, and it says exactly what comes out in the image you posted, in Uncle I also put the table you put in so that if you want you can take a look at it and see if there is something wrong or not... I don't know where to put your hands
I saw the table in the certain zip, in fact I used that to make the screenshoot.
from my experience in the sheet industry, or copied the bending table that was on the machine (if the equipment is in the house and therefore we were wrong of the possible error given by solidworks), or we were given the k values from the supplier.
tell you where the k is wrong... if the table you populated it or with the machine table or with the data values from the supplier, those are. Just tell you about the solidworks alert at this point.
Simone. ..leaving the correct k value or not to realize the piece, my problem now and understand why solid error...I can not model pieces where at the opening signals an error..if I do not solve I can not use the tables
file table and proof made by me...k are randomly shot
