If I didn't get it wrong, you want to create the small tube with that load.
for how I see it there are 2 solutions.
1 If you make a revolution make a plan ofset from one of the faces of the big tube, you draw the profile that interests you with the silhouette downwards (great as in the last attached image) and define the intersection point as already explained.
2 If you do an extrusion, it is more complicated to explain but I try; do a sketch on one of the faces of the big tube where you draw an axis that will be that of the small tube and a sketch point you will put coincident with the edge and will have as distance the diameter of the future tube. Successively create a plane using the perpendicular one to the direction of the small tube and the sketch point (you have to select only that not the whole sketch so keep the latter visible). now create an 183 osfest plan from the newly created one. Finally on this floor you do the sketch of the pipe and shoot it as much as you want.
the problem of putting that length is in the "simple" that you want to parameterize it before creating the extrusion of the horizontal tube.
In that case you have to work ingenuity by circumventing the problem.
notice: make the tube that you will have to parameterize longer than the need, viewing the video you will understand.
I always say you're a big mike... thank you so much now I try to do it and I'll let you know. .another thing mike but how do you make it so shiny this material what imposti looks really stainless I never managed....
