deform/all-heavier sketch
  • Thread starter Thread starter cougarz
cougarz
hello to all
I need to change the proportions of a pretty complex sketch with the company logo. making copy/paste makes me change the scale and rotation but not the proportions between vertical and horizontal. to understand the logo is inscribed in an ellipse now, I would like to inscribed it in a circumference
hello to all
but with relationships? (instruments -> relations)
You can do a lot of things. :wink:
Bye!
p-h
I don't know, I just used them to tie the parameters between them...
consider that the logo consists of a hundred spline, it is really complex!! how can I change for example all y elongating them by 10% leaving the xs unchanged?
directly from pro-and I never did, in similar cases I always exported the sketch in dwg and with autocad is very easy.
If you don't find anything better... think about it.
you can apply the withdrawal. remove the tick from isotropic and exit 3 boxes per axis x,y,z.
so you can resize your logo every independent axis.
fabio.
