delete ole object from command line
  • Thread starter Thread starter czar
czar
I need to delete a logo inserted as an object ole image bitmap from an archive of nmila drawings, would I need to put together a macro to not open them one to a...suggestions? autocad I used it until 2004 have patience for me now is prehistory... thank you to those who will want to help me.
the correct section is autocad, more frequented.
However you can do a script if you know the commands launched
do the first drawing, press f2 and open the window with the command historian
Bring them back to the excel file that you find in the forum and launch the operation. The script may need some adjustments, but you'll only know if you try it
I found a lisp that does to my case and works, now I try to create the script.
