delete parameters
  • Thread starter Thread starter blubossa
blubossa
I have several thousand parts with the most diverse parameters among them....
is it possible to create a macro that deletes all parameters of a part / together?
bb
The only answer I know is model check, but don't ask me more because I don't know how to use it either.
Yes. I think the best solution is model check also because you can do it in batch mode without opening the files. While with a macro, if possible, you should still open one by one.
Yes, but how do you do it?
because it seems to me that it only provides me with a report and I do not find any command that allows me to operate with the parameters.
I have neither intralink nor windchill.
I know the potential of model check, because I have documented and followed the various discussions, it has been treated many times, if you look for it you find different, but still I have not found the time to use it. I know you can do it, but I don't know all the steps.
must be used distributed pro/batch by specifying the "modelcheck" action, obviously modelcheck must be configured specifying that, when called "batch", it should perform an action of deletion parameters
