MARCOC Guest May 26, 2016 #1 I have tried to reassociate a file in which inside there was a derivative, to which I changed my name and exit this message? ? ? ? that I never remember seeing in early versions of inventor, I used 2016 someone can tell me how to fix it Thank you very much
TECNOMODEL Guest May 26, 2016 #2 no longer finds the file because you changed his name. Did you try to give theok? What's going on?
MARCOC Guest May 26, 2016 #3 hi technomodel, pultroppo nothing tells me that and imopossible to solve the file and does not make me continue, I call back the selection of the original file to the infinite
TECNOMODEL Guest May 26, 2016 #4 I guess it happens to change the file name. Try to rename it exactly as it was before, but I have doubts that it settles.
Cast16 Guest May 26, 2016 #5 if you do not solve as technomodel says, try to restore the file from old versions folder.. .
