VincenzoBattista
good morning, use solidworks 2022 at work, and from this version they also gave us the license of toolbox.
using it we saw that there is a problem with the generation of the description screws.
1) we select in "project library " the iso standard
2) we select "bulbs and hexagonal head screws"
3) we draw "hexagonal head screw grade ab - iso 4017" in the axieme
4) we define the necessary parameters e.g. "length" and any others.
5) we give ok
the description appears in the separate materials: "headed hexagonal screw degree ab - din en 24017 - m6 x 25", which obviously does not seem to me what has been done in place of iso
if we do the same procedure, after changing the language of solidworks in English, in the distinct materials the description is: "hexagon head screw iso 4017 - m6 x 40", which is right having chosen a iso screw.
I asked if there was the possibility to have the description in iso also in solidworks with interface in Italian and not in din.
Has anyone had the same problem solved it somehow?
5) we give ok
