design a tool
  • Thread starter Thread starter NL2500SY
NL2500SY
Hi, I'm new in the forum, which I'm beginning to know, and so I apologize if by chance the topic had already been dealt with.
I would need to understand how to draw a custom tool that I can then use in turning.
I would also have done the design but then how I can make it known to the program and then use it.
thanks to those who help me
Hello, did you look in the tool library?
to draw or better "create" a tool you can go in library tools e con create new tool from the dimensions, radiations and profiles of your need starting from basic/standard tools... in addition to giving speed, compensation, passing settings in percentages or mm... and much more. the tool you create will be displayed correctly even when you use verification
Hello, thank you. Then at the end of the day, I realized where my mistake was.
I had created the design of the iron but not diversifying insert holder from the insert. I practically drew the tool from the shape of the plaque and did not close the profile. As soon as I closed that made me create it and use it, a couple of adjustments to make him see correctly the encumbrances and then everything ok.
I am self-taught and not yet all the functions I know them well, and I can explore a bit only when I have processes in my car a little longer
