mrmarkus
Good morning to all, I am new to the forum so I apologize early if my discussion is in a wrong section.
I just started working with solidworks and I have zero experience in prototyping so I wanted to ask someone more experienced than me (and it takes little) some advice on the management of a model that I'm doing in solidworks.
I tell you briefly what this is about.
the project is very simple, I should make 2 plates of equal size one of which with a cylinder extruded in the center (diameter 20mm, extrusion 10mm)
the other 10mm thick plate should have a hole in its center so that the two plates can be coupled but not framed.
once the two models are made, I would like to send them to a workshop that works in cnc to be made of aluminum, now my question is:
Do I have to take into account scraps or tolerances in the construction of models? to be clearer, in the plate with the hole, for example, would I think to prepare a hole slightly larger than 20mm, but how much so that there is no excessive gap? or is this type of tolerance already prepared in the export of the file from solidworks?
thank you all for the advice and excuse for the banality of my question
