dema
for need of a customer we need to change a particular standard but such change is only valid for him so a custom code is created that modifies a standard code with quotation only the necessary processing for the change.
then we will have the following structure:
customized. ♪
standard.asm
Sandard.prt
commercale_locked.prt
now the modification that you can see in the prepared annex specially I created a background in correspondence of three 2 threaded holes and one no, the two threaded holes were made in two different ways one is a threaded hole of pro/e the other is a hole plus a thread cosmetic.
we come to the problemas seen in the table "modification_per_client" the extrusion that creates the background does not change the length of the threaded tract.
I can of course not change the "particular_archiviato_standard" so I can only act in the "modification_per_client" and possibly in its table.
the various tricks to cut the cosmetics I know only work on part level but here we are together.
I ask you for help:
customized. ♪
standard.asm
Sandard.prt
I ask you for help:
