design parapetto
  • Thread starter Thread starter maxmazzinghi
maxmazzinghi
Hello, I am trying to model with inventor 2011 the enclosed parapet.
I follow this procedure:
I do the skeleton sketch,
I create frames in round tube
I create apart the basic plates
And now the beauty comes.
how do I cut two corner bases and which reference I take for the constraints for the base plates since I only have circumferences?
Thank you very much for your help.
bind the plates to the skeleton sketch and then cut the pipes to the plates, otherwise always in the frame sketch create the floors that you will need to bind the plates or cut the pipes.
I would make a small hole on the plate (or a light circular extrusion) that you need then to use the insertion bond with the circumference of the pipe.
Now that I think about it. it seems to me that even if you do only a circular sketch on the face of the plate, you can use it as a guide for the insertion bond
if this plate has been designed centered on the origins, you can also use the central point as entity to be bound to the frame sketch (to understand the vertical lines of the posted image), then with an angle bond of 0° regarding the tilted line always of the frame sketch
What do you mean by "corner beds", is the name of a function (not conocsco inventor) or what else?
