michelefiorentin
Hello everyone,
to practice on the surfaces I tried to "emulate" this beautiful video tutorial your youtube describing the creation of a parametric hull.
Thank you so much for the creator of the video, even if you skip some critical steps.
what I managed to do following his directives (I had to reconstruct some steps) is a hull with discontinuity!
the hull that realizes with the various sections (without bow therefore) already has a tangence discontinuity in the lower central part (see the yellow line in connect checker, although the resulting surface can be thickened).
I don't like using the symmetry for the fillet in the upper part of the bow, I would have used an extrusion.
but the main question is why he chose the solutions reported, especially those per minute 3:06 and that I show in figure. in practice I can't tell the right part of the figure.
I wanted to ask experts some advice about it, before trying alternative ways that my (small) experience teaches. every advice is well-known!
allego file
Thank you so much for the creator of the video, even if you skip some critical steps.what I managed to do following his directives (I had to reconstruct some steps) is a hull with discontinuity!
I don't like using the symmetry for the fillet in the upper part of the bow, I would have used an extrusion.but the main question is why he chose the solutions reported, especially those per minute 3:06 and that I show in figure. in practice I can't tell the right part of the figure.
I wanted to ask experts some advice about it, before trying alternative ways that my (small) experience teaches. every advice is well-known!greetings
allego file
