strafede86
hello, does anyone know if the sw2010 can detect interference between feature on the same body (for example between two holes)?
in the "assieme" environment you can check it, even on bodies the same part.hello, does anyone know if the sw2010 can detect interference between feature on the same body (for example between two holes)?
I'm hard. . .perhaps I did not explain myself well: it happens that one hole intersects another without the designer to notice; for example a threaded hole inside another hole (image image image)
I want to be able to intercept interference like this...
